June 02, 2020, 11:59:48 PM
CB performance Hex bar linkage for t1,t2 and DRLA/IDF carb's
This is a discussion for the topic CB performance Hex bar linkage for t1,t2 and DRLA/IDF carb's on the board Parts Wanted.
Author Topic: CB performance Hex bar linkage for t1,t2 and DRLA/IDF carb's  (Read 679 times)
this user is offline farmer rob
  • northants
  • SWB Rat
Hi Guy's, anyone got a CB performance Hex bar linkage for sale? I have bought an engine which has the carb's, filters, cast filter houses and drop links. So I need the Hex Bar and the 3 arms. Or does someone know where I could buy a new one from, so far I have only found complete kits.
Cheers Rob
  • northants
  • SWB Rat
Reply #2 on: November 23, 2019, 11:33:30 AM
Cheers Dave, they sell the bare hex bar and all the other linkages but I need the arms that the throttle cable and drop linkages fasten too
this user is offline Zip Buggy
  • Bourne, Lincs
  • FF Buggy LWB
    • Zip Buddy
Reply #3 on: November 23, 2019, 12:42:19 PM
I do believe I have what you need Rob.
  • northants
  • SWB Rat
Reply #4 on: November 23, 2019, 03:46:44 PM
That sounds good :D Most of the hex bar linkage's are like this one in the photo but the CB performance ones have the ball ended bolts in the air filter castings, unlike this one, which has the ball ended bolts in the hex bar itself
So I need the hex bar with the arms on as shown in the photo but a CB one  ;-)up
Here is hoping, Rob
  • Edit Enabled
  • Leeds
  • Mk2 Volksrod
Reply #5 on: November 23, 2019, 10:16:29 PM
Can't help out with the linkage, but just wondering if it's for an engine you're putting together to sell. I need to get one for my buggy, or get one built/re-built.
  • Bourne, Lincs
  • FF Buggy LWB
    • Zip Buddy
Reply #6 on: November 23, 2019, 11:49:05 PM
Rob, it's the one I took off my buggy when I fitted the bellcrank. The air-filter castings had a vertical arm with a threaded hole and the ball bit stuck out from there. I've removed that bit from the casting but have the hex bar with all three arms. The hex bar has a recess in each end but I don't have springs and cups if there are meant to be any in there.
Any good to you?
  • northants
  • SWB Rat
Reply #7 on: November 24, 2019, 11:35:39 AM
Hi Mark, they sound good to me. Let me know how much you want for them and how to pay you. Are you still on the same phone number
Cheers Rob
  • northants
  • SWB Rat
Reply #8 on: December 02, 2019, 02:03:55 PM
Sorted, thanks to Zip Buggy ;-)up
  • Bourne, Lincs
  • FF Buggy LWB
    • Zip Buddy
Reply #9 on: December 02, 2019, 04:04:02 PM
Always nice to be able to help you out back Rob :D
