May 28, 2020, 01:20:01 AM
Fuel lines - best material and gauge
This is a discussion for the topic Fuel lines - best material and gauge on the board Beach Buggy Engine and Exhaust Help.
Author Topic: Fuel lines - best material and gauge  (Read 325 times)
this user is offline neilpop
  • Jr. Member
  • Walderslade
  • Sidewinder
on: October 25, 2019, 02:55:49 PM
Hi I'm looking for some advice on which material to use for a fuel line, from what I've read kunifer or PTFE are the best but I also wanted to ask what gauge to get?
I have a twin port 1600 with single carb but have a set of twin carbs to put on.
I plan to run the fuel line down the outside of the tunnel similar to the brake line.
Appreciate any guidance anyone may have.
Cheers,
Neil
  • Henlow, Bedfordshire, UK
  • FF LWB
Reply #1 on: October 25, 2019, 02:58:36 PM
8mm kunifer will future proof you
Reply #2 on: October 25, 2019, 04:06:21 PM
Tank outlet is 5.6 mm so you need to step up to 8mm and you may need to step down to the carb or carbs. Larger webers etc use 8mm.
Fuel injection hose has thicker wall and hopefully lasts longer than standard hose.
Reply #3 on: October 25, 2019, 07:44:24 PM
WHS ^^
And an easy and inexpensive way of stepping up and down are those cheapie "annually disposable" plastic inline fuel filters as they are often stepped to accommodate both sizes.
  • Edit Enabled
  • Leeds
  • Mk2 Volksrod
Reply #4 on: October 25, 2019, 08:17:22 PM
this user is offline pepsi81
  • Whitehaven, Cumbria
  • Purple GP 2
Reply #5 on: October 25, 2019, 09:11:21 PM
Standard 5.6mm pipe, converting to 6mm O/D ptfe (ethanol resistant) lined aeroquip for me. Pressure regulated down to feed twin Kaldrons.
Works for me ;-)up
  • Jr. Member
  • Walderslade
  • Sidewinder
Reply #6 on: October 28, 2019, 07:11:49 AM
Great, thank you all for the advice  ;-)up
