Hey all,
Finally after much delay got the replacement 1600 engine in & running- to be met with an immediate oil leak!
The leak is on the left side top of the engine, at the base of the oil cooler. Rev the engine and the leak increases significantly spraying oil towards the front of the buggy- at least my oil pump is good!
Engine came without an oil cooler or mount.
I bought a 2nd hand genuine mount and a new oil cooler from machine7 with seals.
Not sure if I’ve fitted a seal wrong, neglected to tighten a nut or two or...?
It pains me to ask, but is there anything I can do in situ, or have I got to drop the motor again
Hohum!
Andy
