April 22, 2019, 05:40:17 AM
engine tuning on my bug
This is a discussion for the topic engine tuning on my bug on the board Beach Buggy General Help.
Author Topic: engine tuning on my bug  (Read 278 times)
this user is offline evans794
  • Jr. Member
  • Carterton, Oxfordshire
  • 1972 JAS beach 1641 engine
Reply #15 on: April 16, 2019, 08:05:13 PM
yes single i have just been out and taken the idle jets off and they look very clean but i did clean them anyway i really do think its the settings on the carbs but i dont no how to set them up not a clue  ::)
Rob :)
  • Henlow, Bedfordshire, UK
  • FF LWB
Reply #16 on: April 16, 2019, 08:37:33 PM
the reg is before the fuel pump
Regulator should be after the pump not before as you are controlling the pressure into the carbs, not restricting the flow into the pump
I believe it should be 1.5 - 2.5 PSI
  • Jr. Member
Reply #17 on: April 16, 2019, 09:00:29 PM
will refit tomorrow and see many thanks  :)
Rob :)
  • Jr. Member
Reply #18 on: April 17, 2019, 08:51:25 PM
Regulator sorted , took the fuel reg off all is back to norm (default) did timing still the same, did plugs still the same, checked ht leads and coil, tried to do the rich settings but still no ider why this is still doing the same thing  jerking at constant speed in each gear going to give up soon driving me mad
Rob :)
Reply #19 on: April 17, 2019, 10:57:52 PM
needs an engine tune up and carbs resetting from scratch.  I am 30 odd miles away and prefer cars here as going mobile I often need stuff that I left at home or could not carry,
basic carb setting is on linkage off to separate them.
idle speed screws out clear of the stop plate then in until they touch + 1/4 turn
mixture screws fully in gently till they stop then out 1.75 turns
then it should start and run
if too slow both speed screws in another 1/4 turn
at this it should be drive ok but need fine tuning on mixture and speed
Reply #20 on: April 18, 2019, 08:15:58 AM
@Rob,
Let me translate that for you . . .
Find a way to drive 30 miles and get it to Snoopy, because he WILL fix it   ;-)up
  • Lowestoft, Suffolk
  • GP Mk2 Super Buggy LWB
Reply #21 on: April 18, 2019, 11:03:53 AM
Or buy a book ??? ???
  • Jr. Member
Reply #22 on: April 18, 2019, 07:40:55 PM
i will try and get up there in my next 4 off i work shift so next off will be Tues to Friday next week if you send me a phone number i will ring and arrange .. email - robertevans794@btinternet.com many thanks life saver  ;-)(-; or further down the line
Rob :)
  • Jr. Member
Reply #23 on: April 18, 2019, 08:07:33 PM
i ve found your number i will ring you in my next 4 off many thanks
Rob :)
