May 24, 2020, 11:16:46 PM
Windscreen rubber
This is a discussion for the topic Windscreen rubber on the board Beach Buggy General Help.
Author Topic: Windscreen rubber  (Read 2251 times)
this user is offline Dipsy Deb
  • Beach Buggy
  • Gwent
  • LWB Rat
on: March 16, 2019, 11:34:09 AM
Hi All buggy not back together yet but need to order a windscreen rubber for between the windscreen and bonnet.  My measurements are approx 14mm thick and 1055mm long, any suggestions for the best place to get it. Cheers Deb
this user is online snoopy
Reply #1 on: March 16, 2019, 12:10:56 PM
Seals direct do a selection or my last bit for a GP screen frame came from kingfisher kustoms
Reply #2 on: March 16, 2019, 12:40:54 PM
https://www.woolies-trim.co.uk/
Have some good pictures of their trim on their website   ;-)up
  • Henlow, Bedfordshire, UK
  • FF LWB
Reply #3 on: March 16, 2019, 09:34:53 PM
Woolies will be at the NEC next weekend
  • Beach Buggy
  • Gwent
  • LWB Rat
Reply #4 on: March 17, 2019, 12:41:22 PM
Thanks to you all, hope to be at NEC next weekend but not sure yet.  This will be another item to tick off when we put it back together. Cheers Deb
Reply #5 on: March 17, 2019, 03:37:54 PM
drop in onto the stand always good to put faces and names to logins on here.
  • Beach Buggy
  • Gwent
  • LWB Rat
Reply #6 on: March 18, 2019, 11:55:35 AM
Hi All have contacted woolies & seal direct but they either want a picture or diagram.  Can't do either because I don't have a rubber on the buggy.  Can anyone help with a picture of the rubber seal between the windscreen and bonnet please. It's a LWB Rat. Hoping to make the NEC but not sure yet. Cheers Deb
Reply #7 on: March 18, 2019, 05:29:06 PM
Never had a rat screen off but something like he top closing seal that slides into the bottom groove then seals forwards onto the bonnet. 19mm blade may be to short 25mm would give more tolerance. you need the shape and size of the groove it slides into.
https://www.sealsdirect.co.uk/shopping.asp?intDepartmentId=4#31
  • FF LWB
Reply #8 on: March 18, 2019, 05:30:32 PM
Can you do some photos of the screen, so we can see what style you have.
Reply #10 on: March 18, 2019, 09:42:23 PM
there should be 2 screws either end of the bar that pass through the upright legs, take these out and the bar will pull out allowing you to see the size of slot the rubber goes into so you can order the correct profile to fit in.  slide the rubber in and refit the bar then the rubber blade then just sits forwards onto the bonnet as you refit the screen to the buggy.
  • Beach Buggy
  • Gwent
  • LWB Rat
Reply #11 on: March 24, 2019, 07:09:34 PM
Hi Snoopy thanks for the info, was gutted we were unable to get to the NEC the pics posted looked brill, defo going to get to some event this year.  Cheers Deb
Reply #12 on: March 24, 2019, 07:58:47 PM
No problems Deb, to nice today to be inside anyway so will see you over the summer hopefully.
  • Beach Buggy
  • Gwent
  • LWB Rat
Reply #13 on: November 07, 2019, 09:13:47 AM
Hi All been awhile since asking these questions but have been sorting other little problems which seemed more important. Still unsure which rubber to order for between the bottom of windscreen and bonnet.
Did post pics previously but honestly the rubbers all look similar to me.
Any help appreciated seals plus direct have come back with various suggestions 🤔🤔
It's for a LWB RAT.
Cheers Dipsy Deb
  • Buggy Queen
  • Anglesey, North Wales.
  • Meyers Manx UK-00-002
Reply #14 on: November 07, 2019, 09:35:13 AM
I've used R273 successfully in the past, it may not fit your frame exactly but nothing a bit of Evostik can't sort out.
https://www.woolies-trim.co.uk/category/322/rubber-extrusion
