Don`t make the Rookie mistake in thinking that our cars with "reluctantly agreed and shortened chassis" are under the same rules as the normal length Classic car chassis that the gov websites are referring to. I`ve spent a lot of time with exactly that argument and it is very well documented (even if not yet publicised).
Unless you can prove that any replacement structural panels are VAG
Originals, (not aftermarket ones) then the whole Triggers Broom concept just cannot be put into play. I used that example in my arguments with VOSA too and the reply was the same.
Now stop stirring, and just MOT it
