I have a 1972 floorpan I was going to build a short wheel base buggy but I’ve heard of the IVA sounds impossible to pass. Or should I build a long wheel base that I guess I can just get MOT and update the V5 or do I go down the Q plate route. I’d really like a short wheel base buggy, any advice would be appreciated
Jerry... A quick word to answer your question simply.... IVA.....
Not at all impossible but the 2 updates from 2016 & 2018 resulted in a much more dedicated inspection by the vosa examiners. It would be foolish to try to get an iva pass by "cheating the system" as many have done in the past. It was just a matter of time before the powers to be would respond to that and they have.
So... should you go down the iva route? Only if you are prepared to do your homework and religoulsy work to compliance. To do this you need to have certain skills or access to them. These being an ability to weld well or access to someone who can. The abilty to do some fabrication or access to someone who can. The ability to understand auto wiring or access to someone who can. (This includes the specific fog light control and lucas wiring for 2 speed motors).
There is a cost involved of course for all I have mentioned. In addition you will need to transport the buggy to a public weighbridge to obtain corner & total weights. You will need to transport the buggy to your nearest Vosa test centre. (Test takes between 4 to 5 hours). Costs have come down to about £250 I think now for the test. It is rare to pass first time. Then the cost of a second visit after you have complied with failure requirements. (If you can get it back within 5 days.. no cost. If not you have 6 months to return for a reduced fee).
That`s all I am going to say ,,,, Think this should help you decide & above all .. Good luck whatever you do. Paul
