May 25, 2020, 02:23:25 AM
1964 Classic Manx Build
This is a discussion for the topic 1964 Classic Manx Build on the board Members Buggies.
Author Topic: 1964 Classic Manx Build  (Read 2122 times)
Reply #15 on: August 22, 2019, 02:45:59 PM
Looking good  ;-)up
this user is offline Bealzebug01
  • Jr. Member
  • Lichfield, Staffs
  • Prowler
Reply #16 on: August 23, 2019, 11:59:08 AM
Looks good. Not too sure from the photos how flat is the finish you obtained from the Raptor. What size tire and needle to you use and what psi did you spray at? Gun make and model?
Iím looking to use tintable raptor in tinted to act like tough clear coat on my pan and any info on finish would be really helpful
Matt
this user is offline parmaynu
  • Maidstone, Kent
  • Nuffin
    • Old Skool Parts Shop
Reply #17 on: August 23, 2019, 12:36:29 PM
I didnít spray it. It was a cheap hvlp gun with 2mm tip. The finish is very flat but a little rough. I will put another coat on to try and smooth it a little.
oldskoolpartsshop.com
  • Jr. Member
  • Lichfield, Staffs
  • Prowler
Reply #18 on: August 23, 2019, 01:37:48 PM
Thanks for the info. In regard to the second coat, Iím sure I read on Upols site that you are able to flat the first coat before applying second if you want to tidy things up.
Matt
