July 13, 2020, 12:26:48 PM
1964 Classic Manx Build
This is a discussion for the topic 1964 Classic Manx Build on the board Members Buggies.
Author Topic: 1964 Classic Manx Build  (Read 2281 times)
this user is offline parmaynu
  • Maidstone, Kent
  • Nuffin
    • Old Skool Parts Shop
on: November 13, 2018, 03:39:39 PM
Last year my wife bought me a chassis, as a 40th birthday present. Iíve had a few projects before but not managed to finish any of them. Iíve wanted a Manx for so long now so will hopefully have the drive to get this one over the line.
After an early life as a beetle, the chassis started a new life in the Ď70ís as a GP beach buggy. The shell had been moved on at some point and was completely bare by the time I go it. It is correctly registered on the logbook which is the most important thing when building a buggy in the UK. Itís also a 1964 chassis which attracted my attention as it was the year the Meyers Manx first went on sale. As my buggy will be very much an old skool build, I thought it would fit well being a Ď64.
The plan for the buggy is a very simple Manx using as many stock original parts from around the 1964era as possible. Something along the lines of Old Red and the other really early cars.
Iím a stay at home dad with 4 kids who take up the majority of my time so progress will be very slow and bitty!
I donít have and welding or fabrication skills so I sent the chassis to Mark at Flatlands Engineering. Mark have a chassis jig and is very experienced in chassis work. He let me know yesterday that all the welding was complete and it was ready for collection.
Here are a few pictures:
Next step is blasting and paint. Going to be a while before that can happen as funds have been drained!
oldskoolpartsshop.com
Reply #1 on: November 13, 2018, 04:25:42 PM
Hi again Mathew......   keep us posted on this no matter how long it takes.  Have seen Mark`s jig and this is just what is needed to get the chassis perfectly re-aligned...   Have you noticed the old school bit at pan rear outer... fitting a pleat piece... This is how the original manx was done.
  • Maidstone, Kent
  • Nuffin
Reply #2 on: November 13, 2018, 04:34:51 PM
Do you mean on my photos? Iím not sure what bit you mean
  • Maidstone, Kent
  • Nuffin
Reply #3 on: November 13, 2018, 04:49:20 PM
Forgot to say that I also have a donor car to get things rolling.
I also decided to fit pedals from an oval era bug just because I like them best!
this user is online Manxdavid
  • Buggy Queen
  • Anglesey, North Wales.
  • Meyers Manx UK-00-002
Reply #4 on: November 13, 2018, 05:19:10 PM
I'm glad you're going ahead with it but don't think you need to pay out for blasting and pro paint, I've seen wonders done with a cup wire brush in an angle grinder and single pack coach enamel which can be much more durable than 2K paint.
The donor looks great too, a full set of parts, are they real Jackman's on the rear? Too cool if they are!
Oh, and you're building it 'wrong hand drive' by the way! ;D Your donor Bug is 'correct hand drive!' ;-)up
I've got a full set of Manx body support brackets and a column support from a Classic Manx kit if you need to borrow to copy.
« Last Edit: November 13, 2018, 05:33:16 PM by Manxdavid »
Photos printed on genuine ILFORDģ paper.
this user is offline Manxrod
  • Cullompton Devon
  • Myers Manx. MK1GP swb
Reply #5 on: November 13, 2018, 05:27:46 PM
You need to have the buggy finished in your head and donít change your mind. Break the build down into smaller jobs and focus on that and then move on to the next that way you are reaching goals. It doesnít matter how long it take as long as you keep moving forward and when itís done you will have it for the rest of your life. Iím looking forward to following your build  ;-)up 8)
make it if you can.
Reply #6 on: November 13, 2018, 08:47:04 PM
 Good to see yet another build starting and saving an old buggy.  You will need to realign the clutch hook with a packing spacer or move the guide tube in the tunnel to fit the earlier pedals.
Keep us posted even if it is slowly.
this user is offline pepsi81
  • Whitehaven, Cumbria
  • Purple GP 2
Reply #7 on: November 13, 2018, 08:52:47 PM
Nice one. Keep it up. Plenty of support, time will fly, ask Paul 1953  :D
this user is online Hugh
  • North Herefordshire
  • Mantaray Mk II
Reply #8 on: November 14, 2018, 07:36:27 AM
Looks like you essentially have all the basics, except the shell, and sounds like you know what you are doing/embarking upon.
So good luck and I hope this forum helps propel you to your finished gleaming buggy.
Reply #9 on: November 14, 2018, 08:04:02 AM
4th picture down... I have used the word "pleat" but that is not the correct term... The triangular shaped bit welded into the floorpan to create the outer corner when both halves are brought together. This is cut from the original or replacement pan and quite a neat way of tidying up.
Reply #10 on: November 14, 2018, 08:07:16 AM
Do you know what Mathew... I like these best too.
  • Maidstone, Kent
  • Nuffin
Reply #11 on: November 14, 2018, 11:03:10 AM
This is the sort of look I will be going for
this user is offline Keithmanx
  • Beach Buggy
  • Thatcham, Berkshire
  • Manx
Reply #12 on: November 14, 2018, 12:55:37 PM
Nice one Matthew,
keep the updates coming.
  • Buggy Queen
Reply #13 on: November 14, 2018, 04:55:43 PM
64 is a really nice year too, you can legally get away with no seatbelts, red rear indicators, no mot  etc if you choose to.
  • Maidstone, Kent
  • Nuffin
Reply #14 on: August 22, 2019, 02:21:54 PM
Itís been a long wait but I have finally made a little progress. Chassis has now been blasted and Raptoríd.
Went for a HVLP finish to keep it as smooth as possible. Forgot to mask off the chassis number. Thankfully itís still visible!
All the running gear bits are being done to match now.
