I've enjoyed playing around with my carb. I've read all I could find on the web and taken it apart more than once, played with multiple jet combinations, put in a new diaphragm and cleaned it many times, but never managed to fully tune out the low rev stumble off idle.
I think that I may that I got to then bottom if the issue today though. I read somewhere about throttle shaft play and checked mine after a great, but cold, 60 mile run out this morning and sure enough there it is. When the cable first pulls the throttle linkage against the return spring there is a noticeable change in revs before the throttle spindle turns. Pushing the spindle nut with my thumb does the same thing.
Presumably this play leads to a momentary vacuum leak that would cause a lean spot and therefore the stumble?
Not sure whether DFEV carbs can be modified to take out the play - anyone ever fixed this?
Off to do more reading...or look for another Weber
All good fun,
Andy
