March 08, 2021, 09:01:35 PM
Strange clicking noise
This is a discussion for the topic Strange clicking noise on the board Beach Buggy Engine and Exhaust Help.
Author Topic: Strange clicking noise  (Read 468 times)
this user is offline Ade944
  • Newbie
  • St Ives Cornwall
  • Prowler buggy
on: July 17, 2018, 08:33:03 PM
So what's causing this strange clicking noise at this particular point when rotating the engine?
Sounds like it's coming from the left hand of the engine and when it's running there is a loud taping sound coming from left hand rocker cover. Adjusted valves so it's not those.
https://youtu.be/Q5Lf-6Ed0ww
Could it be a Camshaft fault?
Tried taking fuel pump rod. Noise is still there.
Removed plugs to make this video.
« Last Edit: July 17, 2018, 08:38:22 PM by Ade944 »
Reply #1 on: July 17, 2018, 09:20:36 PM
Could be a sticky cam follower, you need to watch the valves as you turn it or put a finger on them to feel any strange movement.
  • Newbie
  • St Ives Cornwall
  • Prowler buggy
Reply #2 on: July 17, 2018, 09:51:21 PM
Yes I thought that too. If I took the rocker shaft off and felt each push rod would that identify if a cam lobe was faulty?
« Last Edit: July 17, 2018, 09:55:26 PM by Ade944 »
  • Newbie
  • St Ives Cornwall
  • Prowler buggy
Reply #3 on: July 17, 2018, 10:02:37 PM
Yes I thought that too. If I took the rocker shaft off and felt each push rod as I turned the crank slowly by hand would that identify if a cam lobe was faulty?
Reply #4 on: July 18, 2018, 08:53:14 AM
A faulty cam lobe gives less lift as it wears and the valve clearance increases. You could measure the travel on the valves but a worn cam should not make a clicking noise. I guess if the back of a lobe was worn and you reset the gap to 6 thou then the extra lift on the lobe ramp could cause a valve spring to go coil bound flexing the push rod a bit of a long shot though.
