April 15, 2021, 09:20:35 AM
AP's 1962 Beach Buggy Resto - Mk5 Volksrod
This is a discussion for the topic AP's 1962 Beach Buggy Resto - Mk5 Volksrod on the board Members Buggies.
Author Topic: AP's 1962 Beach Buggy Resto - Mk5 Volksrod  (Read 77652 times)
this user is offline apmaman
  • Dundee, Scotland
  • 1962 Volksrod
Reply #270 on: August 13, 2020, 10:17:24 AM
this user is online Doon L001
  • Buggy Prince
  • Nr Leek Staffordshire
  • DOON LWB
Reply #271 on: August 13, 2020, 12:45:09 PM
Keep the faith mate, you know how much you enjoy it
Pushrod tubes are an easy fix
Get a GOOD spring loaded set, there's plenty of Chinese junk ones available. New seals.
Jack up one side to move oil across, rockers off,   take out push rods keeping them in the right order for refitting. Break out all the old tubes with a mole grip and brute force
Oil the rubber sealing rings before fitting  Fit new ones with the seals and locate one end then I found putting a piece of tin over the hole in the block you can compress the spring and slide it over the tin to line it up and ease the tin out
Good luck
this user is offline Hugh
  • Buggy Prince
Reply #272 on: August 13, 2020, 01:48:46 PM
Yes Arran, keep the faith.
My Sidewinder has increasingly been running like a bag of nails and a week ago the clutch cable snapped then on the Saturday gathering of buggys in Brum Merscury was 'noting' that there was a 'machine gun' sound coming from ahead in the cruise - where I was - then I had ignition failure. Well whilst I get a new clutch cable I'm temporarily reusing a metal coat hanger to bridge the clutch cable to the clutch arm, Snoopy produced a length of wire to connect the battery direct to the coil allowing bump starting. So yes buggys are a regular source of niggles and I appreciate you are somewhat out on a limb yet we are here to provide morale support and the odd tip - like Dave Doon.
Regarding the rough running/misfires I am going to put in new plugs and leads...
Reply #273 on: August 13, 2020, 02:16:04 PM
As they say keep the faith mate . . .
. . . . You can always ring me and I will tell you how bad mine is, and that will make you feel so much better about yours   ;D  ;-)up  ;-)(-;
  • Buggy Prince
  • DOON LWB
Reply #274 on: August 13, 2020, 02:43:02 PM
That applies to any of us at some point in our buggy journey
Reply #275 on: August 13, 2020, 09:08:36 PM
always willing to have a chat as said.
  • Dundee, Scotland
  • 1962 Volksrod
Reply #276 on: August 14, 2020, 01:44:33 PM
Thanks for the kind messages. Really appreciate it.
Anyone used the scat, CSP or Fast Fab tubes?
Would they be suitable for a 1776? Want to make sure I get the best bits that will work!
  • Buggy Prince
Reply #277 on: August 14, 2020, 05:53:48 PM
Arran my top tip for "...endless misfires. Black plugs.... black oiley plugs ..." is a new set of plugs and HT leads which has just restored my Sidewinder to full functioning.... for now.
The HT leads must be yellow.
