March 08, 2021, 10:01:02 PM
Fuel Hose - Types
This is a discussion for the topic Fuel Hose - Types on the board Beach Buggy Engine and Exhaust Help.
Author Topic: Fuel Hose - Types  (Read 739 times)
this user is offline 59mango
  • Jr. Member
  • Leicestershire
  • Sidewinder
on: September 18, 2017, 10:17:36 PM
Hi
I've been contemplating changing my fuel lines (at the engine end) for braided stainless ones, but I've heard there can be some issues with these.
Does anyone have any experience - good or bad?
this user is offline Flags
  • Dorset
  • Orange
Reply #1 on: September 18, 2017, 10:30:52 PM
Good, but make sure they are ethanol rated.
Don't buy the cheap and nasty stuff, on most dual carb setups you can go AN fittings but it can work out expensive to do it properly.
  • Nr Leek Staffordshire
  • DOON LWB
Reply #2 on: September 18, 2017, 10:31:36 PM
Flexible hose has to be ethanol proof and stainless braid can just hide perished hose so best avoided (IMHO)
  • Dorset
  • Orange
Reply #3 on: September 18, 2017, 10:37:33 PM
They use stainless braided in motorsport even when they are using ethanol as the fuel.
Don't get confused by the stories of standard cotton braided fuel hose perishing.
Buy the right stuff and it is much safer than rubber type hose. (from experience)
  • Dorset
  • Orange
Reply #4 on: September 18, 2017, 10:49:10 PM
Take a look at this shop on EBay, like I said not cheap but rated for methanol and nitromethane.
this user is offline Testa
  • Buggy Baron
  • Swindon
  • Sidewinder
Reply #5 on: September 19, 2017, 06:18:20 AM
Pirtek for all my fuel lines from the tank outlet to the carbs. Can't go wrong in y opinion. Not Cheep but you get what you pay for.
Testa
Reply #6 on: September 19, 2017, 08:06:51 AM
You will know if you have the correct replacement. The hose will be marked accordingly. As the lads say previously pay a few bob more for the rated stuff.
this user is offline pepsi81
  • Whitehaven, Cumbria
  • Purple GP 2
Reply #7 on: September 19, 2017, 10:46:55 AM
As per Flags comments. Mine are stainless braided teflon, mine you they can be awkward to make up. AN fittings all round. Try Torques UK, or Speedflow. As the guys say, not cheap .
  • Bourne, Lincs
  • FF Buggy LWB
    • Zip Buddy
Reply #8 on: September 19, 2017, 01:10:37 PM
I think the correct hose for ethanol is labelled "R9" ?
this user is offline Chad
  • Kempsey, Worcestershire
  • Doon SWB
    • Doon Buggies
Reply #9 on: September 19, 2017, 01:43:01 PM
I went one further and use bio-fuel hose which is almost 100% ethonol proof (if you buy the better stuff as every one else has said).
Even R9 can suffer over time as they keep uping the % of ethenol in fuel.
The key is don't buy cheap from an unknown supplier. One thisng not to skimp on
  • Purple GP 2
Reply #10 on: September 19, 2017, 02:54:10 PM
Chad👍 R9 will still break down
  • Henlow, Bedfordshire, UK
  • FF LWB
Reply #11 on: September 19, 2017, 04:34:50 PM
R9 is high pressure hose, there is also R14 which is the low pressure equivalent.
I'm currently using R9 from tank to chassis and chassis to fuel filter attached to fan housing.  Am switching to landlines across the engine so there is no chance of breakdown of pipe
this user is offline LUDICRUZ
  • Beach Buggy
  • Uxbridge, Middlesex
  • Custom Predator
Reply #12 on: September 22, 2017, 08:00:29 PM
Hey Buddy,
I've used a company called Think Automotive, they are specialists in Oil cooling systems and all aspects of vehicle plumbing for the daily drive or the motorsport industry.
They have made all my plumbing from Brake hoses, hydraulic pedal lines and fuel line. They have a huge range of fittings to suit as well.
Best of all, they will make it all for you onsite and made to measure.
However as mentioned above by others these are not cheap parts. My fuel line from bulkhead to rear fork with all fittings came to just over 50.
Check their website out  www.thinkauto.com
  • Purple GP 2
Reply #13 on: September 22, 2017, 10:15:59 PM
LUDICRUZ , good call. Never seen this site. Mainly used Speedflow direct. Fay Fischer (owner) is ver knowledgable, her background is drag racing. Mind you, as you say, not cheap.
Paul
  • Jr. Member
  • Leicestershire
  • Sidewinder
Reply #14 on: September 28, 2017, 09:57:15 AM
Hey Buddy,
Excellent contact - thanks very much  ;-)up
