Hi all, just been out for a test in the buggy,havnt fitted new inlet manifold yet but after fitting the lower hot air scoop type thingy i bought second hand and modified it a bit to fit in between my barrels i am now getting 120 degree air up my tube to the oilbath filter. I blocked the second inlet with some foam so i am only getting warm air, hesitation 99 % gone so when new manifold and clear heat risers fitted it should be perfect. This is the best its ever run 😁. Alsoi took off the new gas front shocks as some on here suggested and put back the old ones that came with it and yes, less bangy over bumps and less locking up off the front as the weight is shiftin forward now as the shocks give. Well happy, thanks to all again. 👍
