Hi all, just getting bits together and running through the procedure to change my twinport inlet manifold. I have bought the CB one from vw heritage. A query , the replacement which is a touch bigger and they say a bit more free flowing , it has seperate heat riser tubes so i hope less stripdown to change. Some u tube videos show you having to remove alternator and lift fan housing, i can cut off my old heat risers and hopefully wiggle old one out with both twinport castings removed from heads. But i notice the new manifold also has a cast mounting lug below the carb riser to bolt it to the casing somehow. My existing one just sits there without bolting in, this lug also looks a bit close to the fuel pump, do people grind off this lug or does it just sit over the bolt that is bolting the main case together ? Any previous experience of how others tackled this would be a great help. Did way bigger jobs than this but since the buggy is all complete now I. Am finding it a little bit daunting. Sure i will be ok once I get my teeth into it, its just getting started, I have even thought of getting someone else to do it but dont really want to .thoughts anyone? Many thanks.
