May 25, 2020, 01:26:57 AM
Toms fugitive 4
This is a discussion for the topic Toms fugitive 4 on the board Members Buggies.
Author Topic: Toms fugitive 4  (Read 14371 times)
Reply #90 on: August 21, 2018, 04:53:03 PM
good to meet you and see an air cooled running up the hill ;-)up
this user is offline Johnthesparky
  • Beach Buggy
  • North Bucks
  • UVA fugitive 4
Reply #91 on: November 20, 2018, 08:58:56 PM
Not driven the Fug much since its gone cold, we did get to VW Action
And have been doing bits to it since
34ict carbs
Changed the rocker covers
New plug leads
And did an oil change, found there wasnt much oil in the heads, so fitted new pushrods too,  could blow them through but couldnt see through them
Need to get out for a drive and then check we have wet rocker covers
« Last Edit: November 20, 2018, 09:00:42 PM by Johnthesparky »
  • Beach Buggy
  • North Bucks
  • UVA fugitive 4
Reply #92 on: March 10, 2019, 09:52:07 PM
Back in December we acquired another engine
Wasnt quite sure what we had, but turns out its a a really good motor;
Balanced 78mm crank
Bug pack h-beam rods
90.5 Mahle pistons and barrels
Engle fk87 can
1:4 rockers
JMR type 3 ported heads
44idf Webers
Deep sump
Lightened flywheel
Stage 1 clutch
Full flow filter
Turns out it was run a long time back in a buggy called Starbug
Then put under a bench and left for 12 years.
We stripped it and all it really needed was freshening up.
So weve rebuilt it with new bearings, and replaced the cam with a tamer Fk8.
Fitted new tinware and a few other bits
And now have it nearly built up
Still got bits to sort, exhaust etc
But hoping to run the cam in soon and the fit the motor in the summer
Reply #93 on: March 10, 2019, 09:56:45 PM
A good find, Star Bug was used for drag racing years ago.
  • Beach Buggy
  • North Bucks
  • UVA fugitive 4
Reply #94 on: March 10, 2019, 10:45:44 PM
Yeah, by Mike Lewendon.  Had a chat to him on Facebook
He said he ran 12.4 at 110mph
this user is offline apmaman
  • Dundee, Scotland
  • 1962 Volksrod
Reply #95 on: March 11, 2019, 11:36:10 AM
That's pretty quick!
  • Beach Buggy
  • North Bucks
  • UVA fugitive 4
Reply #96 on: March 11, 2019, 02:54:59 PM
Weve swapped the cam, and itll be running filters and silencers so will hopefully be a bit tamer
He did say itd pull 10k rpm in burn out on the old cam
Also if anyone sees PKE 619G then hed like to buy it back  :)
  • Beach Buggy
  • North Bucks
  • UVA fugitive 4
Reply #97 on: August 26, 2019, 09:50:57 PM
Thought I should update this a bit.
We spent a while rebuilding the 2007cc engine.
Rebuild was pretty much a bearing refresh as everything was good but with worn bearings,  we did fit a FK8 cam though.
Id got hold of a spare set of panels, they were rough but we swapped the bonnet over so we can have a go at tidying up the other one.  Fitted this one with aerocatches to make it easier to remove.
We also applied some vinyls to the side panels.
We went to Goodwood for a show and got there and back without major incident (we did get wet though)
Straight after the weekend away, took it for its MOT and it flew straight through with no issues (MOT tester particularly liked being able to walk round and check the lights with the steering wheel in his had to check lights etc)
We then fitted the big engine, and have been sorting out all the teething issues.
We had a problem at the Gathering with crankcase pressure and a leak from the flywheel oil seal, but seem to have sorted that this weekend
